15 usuários online :: Nenhum usuário registrado, Nenhum Invisível e 15 Visitantes :: 1 Motor de busca
 Ola, Vitara d' Aveiro
arct
arct
Número de Mensagens : 257
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Sex Jun 21, 2013 4:29 pm
great vídeo!! your portuguese it's much better now Smile
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Sab Jun 22, 2013 3:21 am
thats why i don´t like that tires
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Ter Jun 25, 2013 2:07 am
Nice videos and nice trails...
The LED/lights modifications are very nice.
I'm thinking about doing the same thing, but every time i see all the work i need to know, i change my mind! Smile
The shaft, it happens! Smile
What shaft is that, i can't figure what shaft it is.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Ter Jun 25, 2013 2:21 am
It is a bit of work, but you remove the parts and work on a table, out of the car, so it is a bit easier, the USB is Nice!! I have a 15cm cable to connect my tablet on the window, so basically no wires are seen.
The shaft is drivers side, broken at the Wheel CV side.
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Ter Jun 25, 2013 4:37 am
OK, it broke at the FWB.
The LEDs i can't do the same setup, as i have a HardTop...
But i will replace the center lamp to direct more light to both sides... I hope! Very Happy
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qua Out 23, 2013 10:27 am
Bosch injetores instalado, mas o poder parece ter ido para baixo? .. Eu acho que eu preciso adicionar mais combustível, causa há menos ou nenhum fumo agora também. A maior pressão de 175bar injetores Bosch provavelmente está precisando de mais força para abrir e, portanto, eu preciso aumentar o parafuso alimentando um pouco.
Bosch injectors installed, but the power seems to have gone Down?.. I think I need to Add more fuel, cause there is less or no smoke now too.  The Higher Pressure of the Bosch 175bar injectors is probably needing more force to open and therefore I need to increase the fueling screw a bit.
Mas, em outro novo, eu comprei um turbo e colector de experimentar on!
heres alguns exemplos.
But in other news, I have purchased a turbo and manifold to experiment on!
heres some examples.
And Finally
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 12:17 am
you never stop!!!!
if the bosch injectors need more pressure to work, then yes you need to increase the fuel flow to increase the pressure in the fuel rail.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 3:48 am
you never stop!!!!
I don't like TV or Foot-ball, So I have some spare time!
(Love Walking Dead Tho!!! What a Face  )
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 4:00 am
JamesPT escreveu:
you never stop!!!!
this is what I say to my wife, but she does not understand me.
She thinks that the time i spend ond the cars is a waste of time Razz
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 8:18 am
Wifes, always there for you... ;-)
James, nice looking turbo you got there, what are you planning on doing to the vit this time? Flying over mud?!?
Laughing
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 9:33 am
Silva escreveu:
Laughing
Go to 10:00
Tried that, Doesn't work
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Out 24, 2013 9:59 am
Nice! Where there's a will.... Twisted Evil
Idade : 47
MensagemAssunto: Updates   Sex Dez 20, 2013 3:01 am
Desculpe, está em Inglês, mas você pode ver meu trabalho.
Idade : 47
MensagemAssunto: Bosch LDA pin mod   Qui Dez 26, 2013 2:55 pm
Eu comprei um pino Bosch LDA, que como você pode ver, eu tenho modificado para permitir Menos combustível com baixo boost e mais combustível com alto boost.
Vou relatar meus resultados.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qui Fev 27, 2014 4:03 am
Ola, não há muito trabalho ou atualizações foi realizado.
Eu fiz no entanto, atualizar meu de suspensão ao tipo 4xFourArt Extreme.
Que puxa a roda dianteira 3 + para frente. Permitindo que os tipos maiores.
Veja as fotos.
Ah, e em outras notícias, Depois necessidade de substituir o rolamento do pinhão, eu instalei um auto-locker LockRight na traseira (peça n º 1532).
É uma coisa barulhenta, mas faz bem o seu trabalho. Desculpe, não fotos.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qua Abr 02, 2014 7:42 am
Vitara recebendo alguma proteção
E em Outras Notícias ......
Se alguém está se perguntando sobre o sexy vermelho, não é pintar, a cerâmica! 900Deg!
Zircotec's Ceramic Thermohold
e TB mais...
Maior intercooler
Dupla (não mostrado) 7 "Ventiladores, (Para substituir a marca branca eu já tinha que falhou!)
Almofadas da mola
Suporte da bateria (para substituir o madeira que estou usando agora  lol!
E um controlador de ventoinhas programável e variável
Também!
Eu tenho um coletor de entrada em uma loja para ser De-EGR e interally modificado para remover a caixa de refrigeração a EGR, e limpo e pintura.
Número de Mensagens : 703
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qua Abr 02, 2014 10:01 am
Grandes melhorias, parabéns... Smile
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qua Abr 23, 2014 9:40 am
Rear Bumper and Sliders
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Sex Jun 27, 2014 7:41 am
Quase nada de novo na idade, não ter sido fora de estrada desde março!
Mas eu finalmente consegui retirar minha cinta bateria de madeira!
Ah, e uma bateria Optima Yellow!
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Sex Ago 22, 2014 4:53 am
Preparando-se para o Outono.
A maioria das peças, você já viu, é um novo colector de admissão Azul, com a EGR fechada e cortar internamente.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Seg Set 08, 2014 3:46 am
Quase !!
Última edição por JamesPT em Qua Nov 25, 2015 8:15 am, editado 1 vez(es)
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Seg Dez 15, 2014 7:58 am
Finalmente de volta na minha mão depois de uma longa ausência, com muitas interrupções nos mecânica.
Toda a parte dos postos de passagem estão instalados, e trabalho, mas agora eu preciso para o trabalho elétrico.
Solenóide do motor de arranque está agindo de forma engraçada, e as fechaduras das portas e janelas precisam de mais atenção.
Claro, eu nunca sou um para Pare de fazer planos e coletando partes, então aqui a minha próxima atualização, após a fixação dessas questões.
2x Resplendor montar luzes de nevoeiro, grande teste padrão, 16W ~ 1000 lum.
4x Mini 7 "Led Combo, 40W ~ 3200 lum, que eu estava planejando usar nas laterais, mas são quase a brilhante para usar nas laterais.
Eu estava planejando um bar de 20-30 polegadas para o telhado, mas estes são tão brilhante, eu posso simplesmente usá-los no telhado, de frente para a frente, e obter algum 15w-mini na parte traseira e lateral.
kit disco traseiro de Zanfi, ainda está faltando algumas partes .. eles não têm em estoque.
Este kit permite o uso de Fiat Stilo Compassos traseiros, com o apoio do travão de mão.
P.rocha
P.rocha
Número de Mensagens : 321
Data de inscrição : 30/09/2010
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Ter Dez 16, 2014 2:33 pm
So mimos para o vitara +e assim mesmo.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Dom Mar 15, 2015 4:25 am
minor update, os faróis de nevoeiro estão instalados.
Idade : 47
MensagemAssunto: Re: Ola, Vitara d' Aveiro   Qua Mar 18, 2015 4:42 am
Desculpe, está em Inglés
Página 5 de 7Ir à página : Anterior  1, 2, 3, 4, 5, 6, 7  Seguinte
