16 usuários online :: Nenhum usuário registrado, Nenhum Invisível e 16 Visitantes :: 1 Motor de busca
 Caracteristicas técnicas
Idade : 56
MensagemAssunto: Caracteristicas técnicas   Qui Nov 09, 2006 1:50 pm
Caracteristicas técnicas das Quad e ATV Suzuki
KingQuad 700 4x4
Specs
Engine: 695cc, DOHC, four-stroke, single cylinder, liquid-cooled
Bore Stroke: 102.0 X 85.0mm
Compression Ratio: 10.0:1
Fuel System: Fuel Injection
Lubrication: Wet sump
Ignition: CDI
Transmission: V-belt CVT automatic with high/low range sub-transmission, 2WD/4WD/4WD front differential lock
Final Drive: Shaft drive
Overall Length: 2120mm (83.5 in.)
Overall Width: 1210mm (47.6 in.)
Overall Height: 1220mm (48.0 in.)
Seat Height: 860mm (33.9 in.)
Ground Clearance: 260mm (10.2 in.)
Wheelbase: 1280mm (50.4 in.)
Dry Weight: 272kg (602 lbs.)
Suspension Front: Independent, double A-arm, oil-damped, five preload settings
Suspension Rear: Independent, double A-Arm oil-damped, five preload settings
Brakes Front: Dual hydraulic disc
Brakes Rear: Sealed hydraulic disc
Tires Front: AT 25 x 8-12
Tires Rear: AT 25 x 10-12
Fuel Tank Capacity: 17.5 liter (4.6 gal.)
Color: Black, Green, Red
Vinson 500 4x4
Specs
Engine: 493cc, SOHC, four-stroke, single cylinder, liquid-cooled
Bore Stroke: 87.5 X 82.0mm
Compression Ratio: 10:2:1
Fuel System: KeihinT CVK36
Ignition: CDI
Transmission: 5-speed with reverse and 2-speed subtransmission, 2WD/4WD front differential
Overall Length: 2095mm (82.5 in.)
Overall Width: 1170mm (46.1 in.)
Overall Height: 1235mm (48.6 in.)
Ground Clearance: 250mm (9.8 in.)
Wheelbase: 1270mm (50.0 in.)
Dry Weight: 274kg (604 lbs.)
Suspension Front: Independent, double A-arm, oil damped, five preload settings
Suspension Rear: Swingarm-type, oil-damped, five preload settings
Brakes Rear: Single hydraulic disc
Fuel Tank Capacity: 19.0 liter (5.0 gal.)
Color: Advantage® Max-4 HDT
Eiger 400 4x4
Specs
Engine: 376cc, SOHC, four-stroke, single cylinder, air/oil-cooled
Bore Stroke: 82.0 x 71.2mm
Compression Ratio: 9.0:1
Fuel System: KeihinT CVK32
Ignition: CDI
Transmission: V-belt CVT automatic with high/low range sub-transmission, 2WD/4WD front differential
Overall Length: 2175mm (85.6 in.)
Overall Width: 1145mm (45.1 in.)
Overall Height: 1200mm (47.2 in.)
Seat Height: 830mm (32.7 in.)
Ground Clearance: 235mm (9.3 in.)
Wheelbase: 1270mm ( 50.0 in.)
Dry Weight: 268kg (590 lbs.)
Brakes Front: Dual hydraulic discs
Brakes Rear: Single mechanical drum
Fuel Tank Capacity: 15.0 liter (4.0 gallon)
Color: Red, Green, Black
Ozark 250 4X2
Specs
Engine: 246cc, 4-stroke, single-cylinder, air-cooled, SOHC, 2-valve, TSCC
Bore Stroke: 66.0 x 72mm
Compression Ratio: 9.2:1
Fuel System: MikuniT BS29
Ignition: Digital/transistorized
Transmission: 5-speed with reverse, automatic clutch, 2WD
Final Drive: Shaft
Overall Length: 1800mm (70.9 in.)
Overall Width: 1045mm (41.9 in.)
Overall Height: 1070mm (42.1 in.)
Seat Height: 785mm (30.9 in.)
Ground Clearance: 210mm (8.3 in.)
Wheelbase: 1140mm (44.9 in.)
Dry Weight: 183kg (403 lbs.)
Suspension Front: Independent, double A-arm, oil-damped, 5.5 inches of travel
Suspension Rear: Swingarm-type, oil-damped, 5.5 inches of travel
Brakes Rear: Mechanical Drum
Tires Front: AT 22 x 7-11
Tires Rear: AT 22 x 10-9
Fuel Tank Capacity: 10.6 liter (2.80 gallon)
Color: Green, Red, Black
QuadRacer R450
Specs
Engine: 450cc, 4-stroke, single cylinder, liquid-cooled, DOHC, 4-valve
Bore Stroke: 95.5mm x62.8mm
Compression Ratio: 95.5mm x62.8mm
Lubrication: Semi-Dry sump
Ignition: CDI
Transmission: 5-speed constant mesh
Final Drive: chain
Overall Length: 1845mm (72.6 in.)
Overall Width: 1245mm (49.0 in.)
Overall Height: 1085mm (42.7 in.)
Seat Height: 780mm (30.7 in.)
Ground Clearance: 240mm (9.4 in.)
Wheelbase: 1285mm (50.6 in.)
Dry Weight: 167kg (368 lbs.)
Suspension Front: Independent, double A-arm, fully adjustable preload, compression & rebound damping
Suspension Rear: Linkage-type, gas/oil damped, fully adjustable spring preload, adjustable compression and rebound damping
Tires Front: AT20 x 7 R10
Tires Rear: AT18 x 10 R8
Fuel Tank Capacity: 10 liters (2.6 gal.)
Color: Yellow, White
QuadSport Z400
Specs
Engine: 398cc, 4-stroke, single cylinder, liquid-cooled, DOHC, 4-valve, TSCC
Bore Stroke: 90.0 x 62.6mm
Compression Ratio: 11.3:1
Fuel System: Mikuni BSR36
Lubrication: Dry sump
Transmission: 5-speed, with reverse
Final Drive: # 520 chain
Overall Length: 1830mm (72.0 in.)
Overall Width: 1165mm (45.9 in.)
Overall Height: 1160mm (45.7 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 265mm (10.4 in.)
Wheelbase: 1245mm (49.0 in.)
Dry Weight: 169kg (372 lbs.)
Suspension Front: Independent, double A-arm, fully adjustable preload, compression & rebound damping, 8.5 inches of travel
Suspension Rear: Linkage-type, gas/oil damped, fully adjustable spring preload, adjustable compression and rebound damping, 9.1 inches of travel
Tires Front: AT 22 x 7-10
Tires Rear: AT 20 x 10-9
Color: Yellow, White, Black
Também disponivel : Z250 / Z90 / Z80 / Z50
E para os pequeninos apanharem o vicio:
QuadSport Z90
Specs
Engine: 89.8cc, 4-stroke, single cylinder, air-cooled
Bore Stroke: 45.5 x 55.2mm
Fuel System: MikuniT VM17
Lubrication: Wet Sump
Ignition: CDI
Transmission: V-belt, automatic
Final Drive: Chain
Overall Length: 1515mm (59.6 in.)*
Overall Width: 855mm (33.7 in.)*
Overall Height: 865mm (34.1 in.)*
Seat Height: 645mm (25.4 in.)*
Ground Clearance: 150mm (5.9 in.)*
Wheelbase: 1030mm (40.6 in.)*
Dry Weight: 115 kg (254 lbs.)*
Suspension Front: Independent Single A-arm, oil-damped, coil spring
Suspension Rear: Swing arm, oil-damped, coil spring
Brakes Front: Mechanical drum
Brakes Rear: Mechanical drum
Tires Front: AT 19 x 7-8
Tires Rear: AT 19 x 7-8
Fuel Tank Capacity: 6.0 liter (1.6 gal.)
» Comentários sobre o modelo Honda Varadero 125
» Megelli Naked Streetbike 125cc - 125S
» SYM GTS 125 EVO
» cagiva mito 125 estranguladores ?
» Consumo CBF 125
 :: TÉCNICA :: Quad / ATV-
